S-10 & Blazer 1982-2005
91 s10 wiring help
Old Mar 9, 2022 | 12:44 PM
VannihrMorningstar's Avatar
Default 91 s10 wiring help
I'm attempting to bypass my ignition completely and wire in a push to start button, main issue so far is that I'm having troubles locating the proper wires for the install. The labeling for the button have names that aren't the same as the diagrams I've found for my vehicle.
it's a 91 s10 blazer, and if you could help me identify which wires they are, it would be very helpful.
I'm colorblind as well, so that just complicates things even more.
This is the wiring for the PTS system.
This is the wiring I've found for the ignition switch.
Old Mar 14, 2022 | 2:06 AM
Default *solved
So, I did it.
I got it wired in and functioning properly.
Here is the info I was asking for, in case someone else has the same issue.
Thanks for all the help.
All4fun
Mar 5, 2017 10:35 AM
calhoun65
Jan 5, 2015 7:07 PM
Space Dandy
Nov 5, 2014 7:18 AM
krAzi
May 20, 2008 12:08 PM
krAzi
May 16, 2008 6:45 PM
