S-10 & Blazer 1982-2005
93 chevy s10 v6 4x4 power loss
Old May 17, 2009 | 9:34 PM
s1helby1's Avatar
Default 93 chevy s10 v6 4x4 power loss
I just bought a 93 chevy s10 last week. It has ~250,000 miles on it. Once the engine reaches ~190 degrees it begins to bog down and intermittently backfire in the lower gears during take off. If I floor it it will downshift no prob and truck it to cruising speed and accelerate better. It is more pronounced when the temp outside is warmer.
I have already changed
1. air filter
2. temp guage
3. Thermostat, this was a problem but didn't seem to help the power loss
4. Fuel filter
5. distributor cap, cables and button
It idles great and sounds clean. I looked through many forum topics posted here and couldn't find anything similar to this. My next thought is EGR and PCV, then on to more expensive things like catalytic converter. Could anyone give me a little better direction than throwing parts at it. Oh one more thing, Last owner may have let it sit unattended for a while. Thanks
Old May 18, 2009 | 12:03 AM
Mike Sigmond's Avatar
ROTM Coordinator
How old are the spark plugs? Have you checked for any vacuum leaks or the fuel pressure to see if your pump is going bad?
Old May 18, 2009 | 6:17 AM
s1helby1's Avatar
I forgot to post it but yes I changed the plugs, no check engine light but I will check the codes and vacuum pressure this week and post what I find, thanks for your replies.
Old May 19, 2009 | 3:53 PM
s1helby1's Avatar
Default Think I got it
I was reading through the manual again and found that the EGR can cause symptoms like my own. Didn't have a chance to hook it up to a diagnostic tool. I pulled off the EGR and sure enough it was corroded, warn and gunk was clogging it up to the point it whistled when I pushed it in. I changed it out and it has ran great ever since. Although my problem could have been a combination of the above mentioned components I think it is running great now.
Old May 19, 2009 | 4:22 PM
ROTM Coordinator
Thanks for the update, glad you got it running good again
Old May 19, 2009 | 5:00 PM
suzuki-guy's Avatar
I was gonna say EGR or O2 sensor!
justheretohelp
Nov 17, 2014 5:04 PM
Tlindsey099
Oct 7, 2013 10:36 PM
s10contractor
Sep 7, 2011 10:18 AM
novachassis22
Apr 10, 2008 3:12 PM
rteas48183
Mar 18, 2008 4:59 PM
