95 jimmy
Hey everyone!
I have just recently bought a 1995 jimmy... on the way home from picking it up the head gaskit popped... got that fixed and 5 days later the bottom end went out of the engine... Im a honda guy and dont know anything abotu these trucks but I have been told that you need a engine from a 1995 to make it a direct bolt in with no mods needed... is this true? I ask this because I have found a 1994 s10 with the 4.3 in it for cheap! Will this swap work for me or am i going to be screwing around with all sorts of crap?
95 was the transition from the first generation vortec to the current version vortec motors. as far as the 95 you just bought, does it say VORTEC in orange lettering (maybe black) right on top of the motor in big letters, or does it say vortec on a black, plastic square box on the top, towards the back of the motor? does the motor resemble the first pic, or the second?
http://i207.photobucket.com/albums/b...cfrontshot.jpg
http://hooverae.com/upload/files/CPI.jpg
the '94 vortec should resemble the first photo, in which case won't be a direct swap. wiring, computer and all will have to be swapped. much easier to check wrecking yards or craigslist for a motor for the 95 or newer s10's.
but your saying it will all bolt up? i just have to change the harness and ecu? cuz if thats the case getting this truck for 400 bucks seems like the best thing to do to keep cost down
i just dont want to have to be ordering wire conversion harnesses and conversion mounts and bla bla bla know what i mean? i just went through all that with my honda crx... it was a nightmare!!!!!!! if everything bolts up but just needs to be swapped its not a huge deal....
anything can be done. it's just a matter of how much work do you want to do? motor/trans, harness, computer, fuse box/panel, fuel pump for sure, maybe even the tank. if you don't mind doin that much work...
hey again guys... sorry for bringing this old thread back to life again BUT are all 4.3L blocks the same? what if I just got a older/newer block and swapped all my parts onto the new block?
