S-10 & Blazer 1982-2005
97 s10 2.2 no engine power/no codes
Old Oct 22, 2024 | 12:35 PM
Leftysdad's Avatar
Default 97 s10 2.2 no engine power/no codes
97 s10 2.2
bogs/sputters after 3500rpms
Live data shows that fuel system one is stayingstay"OL" open loop even after the truck is fully warmed up to operating temp.....42psi fuel pressure at idel, 45/46 under throttle....
longft1 and shrtft1 are both "0"
No engine codes, just sputters past 3500rpms and has no power to get out of its own way....any advice is appreciated....thanks in advance
(both oxygen sensors good, and egr is new)
map and tps both working well also going by live data
Old Oct 22, 2024 | 4:10 PM
Irish_alley's Avatar
I'm here for the party
had an 02 4.8 that did that. turned out to be the fuel pump. i think what happened was the rubber hose at the pump had spung a leak. it would keep up fuel pressure when you would idea but when the truck was under load the demand for fuel was much higher than just under throttle. you couldnt even pass anything, the rpms would pick up but it would go no where. not sure if its the same situation but it might be a good place to start
Old Oct 22, 2024 | 4:13 PM
Leftysdad's Avatar
Even with the fuel pressure numbers being dead on.....not trying to second guess yourself, simple asking, thanks
Old Oct 22, 2024 | 7:25 PM
im with you on the numbers. and i cant remember how mine tested but im almost certain the pump tested good also and was the last thing i replaced. i hate throwing parts at something but after replacing the fuel pressure regulator and the problem not going away i was pretty limited on other options. im not certain if your pump is bad but just revving the engine wont consume as much fuel as trying to floor it while passing someone. so the fuel pump might be putting out the right amount of pressure due to the lower volume required but if you have to up that volume to give the engine more power the pump cant keep up. i would try to set up the fuel pressure gauge so its visible with the hood shut so you can take it on the road and then floor it and see what happens
Old Oct 25, 2024 | 4:25 AM
Leftysdad's Avatar
Matt R.
Jun 22, 2017 7:32 PM
loom383
Jul 11, 2013 9:12 AM
camaro-nut
Sep 1, 2010 10:06 AM
Buck2ooth
Jan 3, 2010 8:53 PM
jhksclemm
Sep 26, 2007 8:59 AM
