S-10 & Blazer 1982-2005
99 Blazer Troubles
Old May 25, 2008 | 3:23 PM
sluntitled's Avatar
Default 99 Blazer Troubles
I've been having overheating issues with my 99 Blazer. It has 130K Miles. Heater doesn't blow hot air. I've had the system flushed, the heater core flushed, new thermostat, replaced the radiator cap and overflow tank. Two days ago I replaced the water pump (after having replaced it just over a year ago) and today it died on me. I'm not much of a mechanic and need some advise. I'm trying to get it Trade Ready so I can get out from underneath all the repairs. It has become a money pit! Last night my wife drove it and when she got home it wouldn't start. I tried it later that night and it started and ran, but sounded like it was bogging down. Today it started, ran for about 3 miles and started to overheat again! It died at a stop light and I had to push it down the street where it still sits. I noticed that the overflow tank was really low, but was too hot for me to check the radiator and I had to get to work. I didn't have any problems with it starting or running until a day after I changed the water pump. What's wrong?
Old May 25, 2008 | 4:12 PM
EvansBlue's Avatar
Default RE: 99 Blazer Troubles
I'm thinking a gasket. Either intake manifold gasket or head gasket.
Old May 25, 2008 | 5:09 PM
sluntitled's Avatar
Thanks for your response!
Would my replacing the water pump have contributed to the gaskets going out? It just seems so sudden.
Old May 27, 2008 | 6:57 AM
shawnvw's Avatar
Banned
Sounds like you have 2 problems....a plugged radiator, and maybe a bad ign module.
Old May 27, 2008 | 2:56 PM
sluntitled's Avatar
Turns out all the back and forth overheating caused a crack somewhere in my engine. The coolant has mixed with the oil! Hooray! Anybody want a Blazer for cheap?
Old May 29, 2008 | 2:41 AM
chevyman1978's Avatar
i dought there is a crack in the engine you blew a head gasket grab a book on your blazer read it and you and one of ur buddys change it it is not that hard
Old May 29, 2008 | 2:34 PM
sluntitled's Avatar
Tomorrow I'm draining the oil and coolant. Was planning on using a block sealer to see if I could remedy the problem. I've got a book (I've had this truck for four years) and it seemed that changing the head gasket was pretty complicated. Maybe I was reading up on the wrong part. It's been known to happen. Thanks for the reply!
hawk265
Jul 14, 2011 7:38 PM
ricbassman
Mar 13, 2006 2:51 PM
Varhalla
Mar 7, 2006 1:20 PM
dmack58
Feb 18, 2006 7:29 PM
mattd17
Jan 29, 2006 3:31 AM
