S-10 & Blazer 1982-2005
99 S10 ZR2 no crank.
Old Nov 25, 2020 | 3:07 PM
Mtluv's Avatar
Default 99 S10 ZR2 no crank.
I have a 99 S10 ZR2 that I am restoring. I have a no crank problem. Testing the starter relay I found that the truck cranks when jumping pin 30 to pin 87. I have 12.33 volts on pin 30 at all times. With the key on I have 11.88V on 30, 11.88V on 86, and 4V on 85. When I turn to start I have 11.88V on 85, 86, 30, and a good ground on 87. The ignition switch and wiring are new. The relay is new. I don’t get voltage unless in park or neutral. If anyone can help I would appreciate it very much! Thanks
Old Nov 25, 2020 | 3:26 PM
kevinkpk's Avatar
Since you are restoring it, look at the wiring.
Old Nov 26, 2020 | 9:43 AM
Check to see that your relay is wired as in the diagram.
https://images.search.yahoo.com/sear...g&action=click
Vikingtu
Jun 22, 2020 10:07 PM
Richard Voss
Dec 4, 2018 2:47 PM
tazmaniac_37752
Dec 19, 2016 8:25 PM
magicc8ball
Feb 7, 2010 6:56 PM
gone_fishing1
Nov 12, 2007 1:37 PM
