ABS light on a 95 chevy blazer 4x4
hi guys ! i am new here ! i have a 95 chevy blazer 4x4 4.3 engine and the ABS light stays on while i am driving ! it don,t seem to effect the braking any but the light annoys me ! i was told by the garage that it could be a wire broke on one of the wheel sensors or one of the plug-ins is corroded ! what,s your thought on that ? also another question if you don,t mind ! once in a great while the servive engine light will come on so i had it checked and the garage said there were no history in the computer but a vacuum hose can cause it to trigger if it,s leaking vacuum ! what,s your thought on that ? thanks guys for your time !
well first off they are prolly right could be a wire broke or just a bad abs sensor. it wont change your breaking just the abs feature of your brakes.. I have never heard of a check engine light coming on and not throwing a code. are you sure the codes didnt get cleared by someone disconnecting the battery or it dying ??
Hrm, well I learned something I didnt know there was away to retrieve the abs code.. Ive only had that problem once and I knew which wheel mine was I tore the wire going to the sensor while doing the steering knuckle balljoint and lower control arm.So thanks MDTAHOE I learned that as well.
A basic OBDII code reader will only read PCM codes. With a full scanner codes can be retrieved from The Air Bag, ABS, BCM, Transfer case, Transmission, IP cluster etc... Full data can be seen from the also
phyberport
December 13th, 2022 8:10 PM
blackedout
November 24th, 2013 4:07 PM
Bulldog9539@gmail.com
September 4th, 2011 2:54 AM
Deteoni
March 28th, 2009 2:39 PM
