S-10 & Blazer 1982-2005
ABS light on a 95 chevy blazer 4x4
Old Feb 26, 2013 | 9:24 PM
bandit_601948's Avatar
Default ABS light on a 95 chevy blazer 4x4
hi guys ! i am new here ! i have a 95 chevy blazer 4x4 4.3 engine and the ABS light stays on while i am driving ! it don,t seem to effect the braking any but the light annoys me ! i was told by the garage that it could be a wire broke on one of the wheel sensors or one of the plug-ins is corroded ! what,s your thought on that ? also another question if you don,t mind ! once in a great while the servive engine light will come on so i had it checked and the garage said there were no history in the computer but a vacuum hose can cause it to trigger if it,s leaking vacuum ! what,s your thought on that ? thanks guys for your time !
Old Feb 28, 2013 | 2:43 PM
spike1269's Avatar
well first off they are prolly right could be a wire broke or just a bad abs sensor. it wont change your breaking just the abs feature of your brakes.. I have never heard of a check engine light coming on and not throwing a code. are you sure the codes didnt get cleared by someone disconnecting the battery or it dying ??
Old Feb 28, 2013 | 8:55 PM
MDTAHOE's Avatar
Professional Mechanic
You need to have the ABS code retrieved to start looking for problem. Without a code anyone is just guessing. Do you feel lucky?
Old Mar 1, 2013 | 1:08 AM
spike1269's Avatar
Hrm, well I learned something I didnt know there was away to retrieve the abs code.. Ive only had that problem once and I knew which wheel mine was I tore the wire going to the sensor while doing the steering knuckle balljoint and lower control arm.So thanks MDTAHOE I learned that as well.
Old Mar 1, 2013 | 10:27 PM
MDTAHOE's Avatar
A basic OBDII code reader will only read PCM codes. With a full scanner codes can be retrieved from The Air Bag, ABS, BCM, Transfer case, Transmission, IP cluster etc... Full data can be seen from the also
phyberport
Dec 13, 2022 7:10 PM
blackedout
Nov 24, 2013 3:07 PM
OkieMudslinger
Mar 6, 2013 10:44 PM
Bulldog9539@gmail.com
Sep 4, 2011 1:54 AM
Deteoni
Mar 28, 2009 1:39 PM
