S-10 & Blazer 1982-2005
ABS problem
Old Dec 14, 2008 | 1:52 PM
gumby197's Avatar
Default ABS problem
My 97 S10 has developed an ABS problem. I changed the brake pads and had new tires put on and now when I turn to the right the ABS kicks in. Just turning the wheel without pushing the pedal or the truck moving. The light comes on when you get about halfway to the right and then it will go out when you go to the left. I looked at the wire and sensors to see if they are pinched and that does not seem to be the problem. Whats going on ?
Old Dec 17, 2008 | 7:06 AM
EvansBlue's Avatar
Default RE: ABS problem
May be that the wheel speed sensor is touching the notchesin the hub. Or possibly that its dirty. [/align]It could just be a bad wheel speed sensor.[/align]
millerlite
Dec 17, 2014 9:20 PM
yfzracer
Nov 2, 2011 9:03 PM
tom_faber
Aug 3, 2011 8:42 PM
kcb37
Jan 12, 2007 7:09 AM
