AC wont get COLD
I have a 96 Blazer and Im experiencing the AC just blowing slightly cool air but no cold air. Ive checked the freon levels and temps are reading good. This check was done with an dealership style AC machine.
Im thinking since its a 96 and even if the compressor is working maybe it needs to be replace.
I guess my question is does the compressor make the temp COLD? I want my joint cold like a new car right now im cool like fan in the shade...can anyone help me thanks in advance for your knowledge and suggestions.
If the compressor was worn out, your pressures would suffer as well as the temperature.
Could you measure the temp at the vent on MAX A/C, Thermostat all the way to blue, and fan on 1? My guess is that its not going into recirc, meaning that you are getting outside air.
Professional Mechanic
Try to pinch the heater hoses closed. If the temperature gets much colder you most likely have a air mix door problem or a heater control valve problem ( if it has one)
Ghughes13
June 24th, 2012 2:19 PM
chevy619
19
February 5th, 2012 8:42 PM
railer689
December 9th, 2010 12:33 PM
Mille Racer 69
17
November 7th, 2010 4:19 PM
