S-10 & Blazer 1982-2005
AC wont get COLD
Old Aug 23, 2009 | 6:04 PM
96 Blazer Dude's Avatar
Default AC wont get COLD
I have a 96 Blazer and Im experiencing the AC just blowing slightly cool air but no cold air. Ive checked the freon levels and temps are reading good. This check was done with an dealership style AC machine.
Im thinking since its a 96 and even if the compressor is working maybe it needs to be replace.
I guess my question is does the compressor make the temp COLD? I want my joint cold like a new car right now im cool like fan in the shade...can anyone help me thanks in advance for your knowledge and suggestions.
Old Aug 23, 2009 | 7:23 PM
EvansBlue's Avatar
If the compressor was worn out, your pressures would suffer as well as the temperature.
Could you measure the temp at the vent on MAX A/C, Thermostat all the way to blue, and fan on 1? My guess is that its not going into recirc, meaning that you are getting outside air.
Old Aug 23, 2009 | 10:07 PM
MDTAHOE's Avatar
Professional Mechanic
Try to pinch the heater hoses closed. If the temperature gets much colder you most likely have a air mix door problem or a heater control valve problem ( if it has one)
Old Aug 24, 2009 | 4:19 PM
Is this major or minor fix?
Old Aug 29, 2009 | 9:30 PM
a. palmer jr.'s Avatar
If the pressures are correct you do not need to replace your compressor. Chances are you are a little low on R134.
Ghughes13
Jun 24, 2012 2:19 PM
chevy619
19
Feb 5, 2012 8:42 PM
railer689
Dec 9, 2010 12:33 PM
Mille Racer 69
17
Nov 7, 2010 4:19 PM
Flying Low
Corvette
Mar 29, 2009 7:56 PM
