S-10 & Blazer 1982-2005
Back Up Lights
Old June 8th, 2007, 3:18 PM
georgep14's Avatar
Default Back Up Lights
Hi,
I am having problems with my back up lights. When I put the truck into reverse, the lights do not come on. I checked them with a meter and I am getting no power. I checked the wiring harness and I couldn't see anything. The wire that leads into the back up lights is a lime greenish color. I have had a lot of problems with the rear wiring harness in the past. I had to run a new ground to get the break lights to work. I have seen that posted a few times before on this forum, but not this issue.
Old September 17th, 2007, 8:16 PM
sickvortech1's Avatar
Default RE: Back Up Lights
hello, i'd check the fueses first,its most likely the neutral safty switch, the back up lights come on only when in reverse i would also suggest the haynes manual for your year truck, it has a full picture of the switch location on page7b3 1982-93 manual and 7b4 1994-2004
TRUCKDIVA
July 22nd, 2013 6:48 AM
DOBERDEWD
December 11th, 2011 11:35 PM
skdevore
August 26th, 2009 10:18 PM
kcornelis4
November 14th, 2007 6:43 AM
reynaldor@spectralby
September 7th, 2007 12:03 AM
Quick Reply: Back Up Lights
