S-10 & Blazer 1982-2005
Blazer-ball joints?
Old May 23, 2012 | 10:16 PM
playboy's Avatar
Default Blazer-ball joints?
hi every time i go over a bump or un even pavement i get a loose clunking sound under wheel wells on front both sides. its gettin to the point where i feel it a bit under my feet. and guy in back seat said the same. the truck has definatly been used.
Old May 23, 2012 | 10:33 PM
Get under the truck and check. Look for anything loose.
Old May 24, 2012 | 7:20 AM
johntaps's Avatar
Former Sponsor
Post 1993 blazer T10 4.3 v6 "noise when going over bumps"lower ball joints?
Have you check the sway bar link?
Old May 27, 2012 | 1:30 AM
playboy's Avatar
i.have movement left right up and down. looss joint movement. but not.sure which part specifically
Old May 28, 2012 | 6:06 PM
beninpa79's Avatar
Sounds like it could be the wheel bearings going bad. Just a thought.
Old May 30, 2012 | 9:10 PM
RacerX's Avatar
your problem in the clunking is MOST likely worn sway bar links. BUT the left right movement when you jerk the tires is MOST likely tie rods outer. The movement on up down jerks could most likely be the lower ball joints. Either way your truck sounds like it needs the entire front end rebuilt.
bigbare01
Jul 24, 2010 11:50 AM
HI808
Mar 12, 2010 3:24 PM
Mr.Cale
Feb 7, 2010 7:07 PM
quinnman105
Nov 24, 2008 1:53 AM
hometheaterman
Mar 30, 2008 2:07 PM
