S-10 & Blazer 1982-2005
Blowing alternators
Old Jan 2, 2014 | 8:36 AM
Ralbon's Avatar
Default Blowing alternators
Was driving 95 S10 blazer, began to notice a strong odor of battery acid. Back in shop the battery had boiled over and the alternator was no longer charging. Replaced batt and alt, all was good for a couple days and alt quit charging. Replaced alt, ok for a couple days alt quit charging. Have replaced alt and now wondering if am getting bad alt's or if something on vehicle is causing failure.
At a loss on this one. Getting alt's from autozone. Have not run vehicle since replacing last alt. Check for short using volt meter, drain is 3.25 volt, only thing to stop drain was disconnecting ecm. Have no way to check amp draw.
Need help with this. Thanks
darknight
K5 Blazer
Apr 23, 2012 9:11 AM
pervitizm
May 12, 2008 4:58 PM
mychevyvan
Oct 23, 2006 1:02 PM
fastblueheeler
Aug 12, 2006 2:53 AM
Fuel
Mar 24, 2006 12:42 PM
