Bouncing Issue
Bouncing Issue
as i am going down the road from about 25 -40 mph my whole truck starts bouncing almost like there is a flat spot on my front tires. i tried changing my outter tie rods. but the problem continues can anyone give me help on how to fix it?
RE: Bouncing Issue
Hi. I had the same problem and shocks fixed it, which is most likely not your problym if it is very bad bouncing, but it worked for me, so it might be worth a try. Good luck
RE: Bouncing Issue
yeah shocks will probably be a fix for it. If not, check your tires and make sure they are balanced. (You may have to take it to a tire shop.)
juddkennedy
15
January 5th, 2011 4:37 AM
meganlkirby
September 23rd, 2008 6:29 PM
