S-10 & Blazer 1982-2005
Bouncing Issue
Old Nov 12, 2007 | 8:24 PM
Fireman436's Avatar
Default Bouncing Issue
as i am going down the road from about 25 -40 mph my whole truck starts bouncing almost like there is a flat spot on my front tires. i tried changing my outter tie rods. but the problem continues can anyone give me help on how to fix it?
Old Nov 14, 2007 | 7:46 PM
sullivkj's Avatar
Default RE: Bouncing Issue
Hi. I had the same problem and shocks fixed it, which is most likely not your problym if it is very bad bouncing, but it worked for me, so it might be worth a try. Good luck
Old Nov 16, 2007 | 3:31 PM
EvansBlue's Avatar
yeah shocks will probably be a fix for it. If not, check your tires and make sure they are balanced. (You may have to take it to a tire shop.)
juddkennedy
15
Jan 5, 2011 4:37 AM
meganlkirby
Sep 23, 2008 6:29 PM
jc2
Mar 25, 2007 8:50 PM
