S-10 & Blazer 1982-2005
A/C Compressor won't turn on
Old Jul 13, 2011 | 3:25 PM
remington22girl's Avatar
Question A/C Compressor won't turn on
Took it to a mechanic and he said the switch is bad, is there any way to bypass this switch and just have it kick on when I turn the AC on? Also, previous owner cut off vents how do I get these to turn back on/switch on
Old Jul 17, 2011 | 5:54 PM
mavmannate's Avatar
That is a very time consuming project right there depending on how many pcs they ripped out. An option would be to tear out the cover for the heater core and put some 12volt fans down there. You will have much more air flow, but you will loose leg room for the passenger.
Old Jul 19, 2011 | 11:11 PM
Well, it is a blazer and the heater core is on the middle hump, plus it leaks and I have to replace it anyways, I will try this and keep you updated. Thanks!
Old Jul 23, 2011 | 1:04 AM
dcw's Avatar
dcw
you can buy a switch at auto zone it only cost about 8 or 12 bucks it is located on the acumalter it has a wire coming wires comin from it going to the compreser as for your other problem i woud go to a salvage and see if i can find those parts
scumpoozie
Aug 15, 2023 9:12 AM
ZChevyAK
Nov 13, 2015 6:45 PM
G T Igofast
Sep 3, 2013 3:46 PM
Steeltown
Jun 22, 2011 8:24 PM
silverado01ls
Jan 4, 2007 6:36 PM
