S-10 & Blazer 1982-2005
chevy blazer ground battery cable
Old Sep 3, 2015 | 1:57 PM
danpino's Avatar
Default chevy blazer ground battery cable
hi my 1997 chevy blazer ls 4wd hit a tree on the ice and since then has had an electrical issue and turns but wont fire. I noticed that of the 3 cables that hookup to the negative on the battery, one of the 2 smaller ones had a break and isnt grounded. The car crashed on the passenger fender so im wondering if this is my problem. I believe this is the g105. is this my issue?
Old Sep 4, 2015 | 11:46 AM
Yes it is possible that this is the problem. Try connecting it back to the negative on the battery to see if it solves the problem.
Old Sep 4, 2015 | 12:38 PM
danpino's Avatar
It's connected to the negative on the battery but it's just not grounded and to get to g105 it will involve removing the radiator. Do you think it would be just as good to ground it in a different yet similar spot?
Old Sep 7, 2015 | 12:16 AM
toocute350's Avatar
It maybe your alternator.Have someone test it for you.If and when a alternator goes out it?your motor won`t turn over.
Old Sep 7, 2015 | 8:44 AM
cars with faulty alternators will start and run as long as the battery is charged
for testing, run a temporary grd to the engine block. the alternator is case grounded.
John96021
Dec 15, 2010 1:10 PM
definity78
Jul 16, 2008 9:53 PM
SuperTexan
Oct 22, 2007 8:26 PM
davemec
Apr 2, 2007 6:09 PM
nytelush
Dec 30, 2005 5:16 PM
