S-10 & Blazer 1982-2005
climate control problem
Old Jul 7, 2008 | 7:11 PM
zr2help's Avatar
Default climate control problem
I am getting this hissing sound from the climate control switch. I have it apart right now and the hissing sound is definatly coming from the switch. Can I grease this switch up or do something to fix this?
Old Jul 7, 2008 | 10:51 PM
EvansBlue's Avatar
Default RE: climate control problem
Year model would be extremely helpful. [/align][/align]Anyway, you might be able to quieten the coils on the switch with some vaseline, but if not, you are looking at replacing the switch.[/align]
Old Jul 7, 2008 | 11:44 PM
zr2help's Avatar
yeah sorry, It's a 2003 GMC Sonoma ZR2. I greased up the connections a bit but it didn't seem to do much. There is a little rubber flange sorta thing, does that need grease? I did notice a lot of oily residue in the area that the climate control cluster is located. let me know what you think.
Old Jul 8, 2008 | 11:36 PM
EvansBlue's Avatar
Are we talking about one of the switches on the dash? Or the valve switch on the refrigerant line?[/align][/align][/align]Anyway, if its the switches on the dash, you will need the switch cluster. Its likely got something burned up in the switch contact.[/align]
hyperlite91193
Nov 8, 2022 10:20 AM
greengumby
Feb 1, 2022 2:12 AM
KBw04.2500
Feb 26, 2019 11:17 AM
fernandito7
Oct 28, 2007 1:14 PM
zapbranagan
Dec 2, 2006 3:33 PM
