S-10 & Blazer 1982-2005
Computer
Old Jul 23, 2007 | 9:55 PM
rbrown281's Avatar
Default Computer
Hi, got a 96 blazer w/v6 W/vin. A few questionsplease. I installed a used pcm (checked out and programed for my vin). I am trying to get the pcm to reset the i/m redieness monitors. Oxygen sensor heater,catalyst, and evaporative system are not resetting yet.I am running through the drive cycles.I might need to give it a few more, the paper work says if the battery is disconnected, it could take 5 cycles to set the catalyst.I think i was having the same problem of resetting, can't remember for sure.Anyone ever have a pcm that wouldn't reset?Also, i was having a problem with the engine dying.I believe it is the coil output for the tach, anyone had a similar problem?Any info is appriciated, thanks.
Old Jul 23, 2007 | 10:37 PM
golfer's Avatar
Default RE: Computer
Are these the reasons for changing the pcm ??
Old Jul 23, 2007 | 11:40 PM
rbrown281's Avatar
I was getting a P 1351 code. After going through a detailed diagnostic print out procedure and not finding anything I replaced the pcm.I even changed coil,module and crank sensor as a try.This code would set going down the roar and also cranking the vehicle.After changing out the pcm on second day it died a few times.some times it would start back run a little and die, sometimes i would have to let it sit a little time.the last time it died i decided to disconnect the coil wire to the tach .It started and has not died yet. Driven the last 3 days trying to reset pcm (some monitors did reset) Has not died yet.I don't know if the tach is failing( just remembered sun tachs going out from my past)
rcbigblock
Mar 27, 2007 9:02 PM
Cv1969Corvette
Dec 3, 2006 7:04 PM
JustMe
Nov 4, 2006 3:14 PM
