S-10 & Blazer 1982-2005
coolant rushing into overflow
Old Apr 8, 2014 | 7:15 PM
nolareese's Avatar
Default coolant rushing into overflow
I'm having a lot of coolant rush into my overflow when I turn off my engine. It is not running hot and I have replaced the radiator(about a year ago), LIM, and thought it was my thermostat which I just replaced. It is not running hot and I don't think I have a leak (at least not one that I can se) but I don't know what the problem is. Any help will be appreciated
Old Apr 8, 2014 | 10:03 PM
if the rad cap (or reservoir cap if it uses a threaded cap on the reservoir in place of the rad cap) doesn't seal the system it will do that. test or replace the rad cap.
Old Apr 8, 2014 | 11:22 PM
nolareese's Avatar
I am going to test that as well as a pressure test the radiator tomorrow(to see if there is a slow leak some where). I did flush out my heater core this past winter because I had no heat, which worked but if there is air in the heater core, would that cause my problem?
Old Apr 9, 2014 | 7:26 AM
no. air in the system would cause no heat at idle
Old Apr 9, 2014 | 9:33 AM
nolareese's Avatar
Can it be that I am not burping the system to get the air out properly because I am doing it only on a slight incline? By the way thank you for your help.
Old Apr 9, 2014 | 2:24 PM
no.
Based on your description on it not overheating and the reservoir filling; imo what is happening is the system is overheating at normal operating temperature. What that means is, the coolant boiling point has dropped because the system can't pressurize itself; due to the rad cap not sealing the system. Every 1 psi the system pressurizes = 3*C raised bp...so x that by a 15psi system.
If your run an engine with the cap removed it will eventually boil over at approx 100*C.
the only reason coolant fills the reservoir is when it overheats; its just overheating at normal operating temp.
I could be wrong, but that's where I would start. a rad cap is cheap and easy and so is a cooling system pressure test.
Old Apr 9, 2014 | 3:43 PM
nolareese's Avatar
I pressure test the system and there was a small hole in one of the heater core hoses(out flow)which was spraying on top of the engine and being blown off while I was driving it. So that is why I didn't see any puddles or drips. Thanks for your help
art331
Jan 1, 2021 1:09 PM
tommyxj2000
Apr 11, 2012 8:41 PM
samger2
18
Jun 2, 2009 1:47 PM
flash12
Dec 23, 2008 10:13 AM
98greenventure
Jul 27, 2007 10:28 PM
