S-10 & Blazer 1982-2005
doing some rework on 2000 blazer with 4.3
Old Sep 8, 2016 | 8:18 PM
onebadolegator's Avatar
Default doing some rework on 2000 blazer with 4.3
Have changed intake and installed carbureator. What can we use for distributer? Caan we still use original one? Thanks for any help.
Old Sep 12, 2016 | 2:29 PM
SBchevyfan's Avatar
You should be able to re-install the original distributor. However, I'm guessing that you're trying to get some better performance by changing the intake and going to a carb. I believe Accel and Mallory make aftermarket distributors for the 4.3. You might want to consider how many miles are on the original and then determine how much performance you want and how much you want to pay for it.
Old Sep 13, 2016 | 2:42 PM
Thanks for the information, still debating this. Since we have to change the fuel pump, for pressure, and a few other changes, we thought we would need to change the distributor. With no fuel injection, will the computer still control timing and all else except the fuel?
Old Sep 14, 2016 | 2:34 PM
SBchevyfan's Avatar
I found some stuff online that may help you. Search 2000 vortec v-6 carb swap. Good luck with your project.
Old Sep 15, 2016 | 8:57 PM
Thanks for the help, I will check it out.
