S-10 & Blazer 1982-2005
Door Panel Removal Help Please!
Old Aug 11, 2007 | 1:15 PM
SlateFox's Avatar
Default Door Panel Removal Help Please!
So im trying to replace the driverside mirror. ive got the door panel hanging but i cant figure out how to remove the manual window regulator. please help? the repair manual said something about a bearing plate but it has no pictures soi have no idea what its talking about. thanks
Old Aug 11, 2007 | 5:50 PM
nrf911's Avatar
Default RE: Door Panel Removal Help Please!
on the other side of the windo crank there should be a clip holding it on...thats the only thing that should be in the way...but i'm no expert so there could be more...
Old Aug 12, 2007 | 2:14 PM
kcb37's Avatar
Are you trying to take out the window crank (handle) or the regulator? If you are trying to take the crank off to get the door panel off, their a c type clip on the back side that holds it on. They make tools to remove them but a screwdriver or two and some paticence usually works. If you are trying to take the regulator off, if it hasn't been taken off yet it is rivited to the door frame with some rather large rivits.
beemerphile
Mar 12, 2008 12:15 AM
MountainMan71
Nov 15, 2007 1:25 AM
Bentley
Jan 26, 2007 1:52 AM
Bentley
Jan 24, 2007 7:46 PM
LeoDuffrin
Apr 27, 2006 10:43 PM
