S-10 & Blazer 1982-2005
Engine Noise Over Radio
Old Apr 26, 2008 | 8:10 PM
SRL S10's Avatar
Default Engine Noise Over Radio
I just bought a 2002 S10 4x4 4.3 with 44,000 miles. Runs great but I get loud engine / electrical noise over the standard radio and my XM radio. Any ideas how I can correct the problem ?
Old Apr 26, 2008 | 8:34 PM
shawnvw's Avatar
Banned
Default RE: Engine Noise Over Radio
factory xm or aftermarket?
Old Apr 26, 2008 | 8:37 PM
SRL S10's Avatar
plug and play XM unit powered thru power port
Old Apr 27, 2008 | 9:39 PM
awright21's Avatar
Any kind of aftermarket amplifier?
Old Apr 28, 2008 | 3:35 PM
shawnvw's Avatar
Banned
Does the noise come through the speakers when using FM radio as well as XM? or just the XM?
If it is just the XM, you could be picking up a lot of noise when using the accessory outlet.
If it is through fm stations as well as when your using the xm, your problem could be a por radio ground, or a poor ground in the antenna circuit...usualy occurs at the antenna base where it attaches to the body
Old Nov 27, 2015 | 1:22 PM
wood's Avatar
have same problem with a 2000 blazer aftermarket and original radio have tried ground to dash havent tried antenna yet
thisnthat
Nov 20, 2012 11:36 AM
karlr
Sep 23, 2010 12:01 AM
adamant
Feb 15, 2009 8:49 AM
nost1
Jan 25, 2007 7:22 AM
