S-10 & Blazer 1982-2005
Engine Shaking
Old Oct 19, 2018 | 11:09 AM
jameszr2's Avatar
Default Engine Shaking
The other day i started my pickup a 2002 GMC Sonoma Zr2 and at idle or even a constant rpm it starts shaking when at a differing rpm it does not shake that i can tell. Any ideas? I checked the spark plug wires, did a tune up a few weeks ago(oil, oil filter, fuel filter, checked all fluids) and that didn't change anything so please if you have an idea say it.
Old Oct 19, 2018 | 6:18 PM
geo1's Avatar
Do you have a black tailpipe?rich condition?
Old Oct 20, 2018 | 7:44 AM
When was the last time you did a tune up on it? A visual check of the spark plug wires doesn't always tell if they are bad.
Old Oct 22, 2018 | 11:06 AM
jameszr2's Avatar
i changed the oil, oil filter, and fuel filter two weeks ago
Old Oct 22, 2018 | 12:12 PM
geo1's Avatar
What about the tune up question?sounds like a mechanic in your area will be best for you, sometimes,diagnosis gets pretty involved
Old Oct 22, 2018 | 2:58 PM
Kazoocruiser's Avatar
From: Currently the Candian Gander is wintering over in New York.
Default The cogitators need more information.
Originally Posted by jameszr2
The other day i started my pickup and at idle or even a constant rpm it starts shaking when at a differing rpm it does not shake that i can tell. Any ideas? I checked the spark plug wires and that didn't change anything so please if you have an idea say it.
I have an idea. Provide more detail about the "pickup" u are trying to fix. What kind of UTE is it? What year, make and model? Vehicles aren't like people. They aren't atomically identical.
If you document what you did to this point to try to fix the problem that would help.
