S-10 & Blazer 1982-2005
Engine Swap 4.3 to 5.3
Old Oct 27, 2015 | 5:21 PM
Darknerocu's Avatar
Default Engine Swap 4.3 to 5.3
Hi Everyone,
Just to start off if anyone has a thread that explains this please let me know. I DID try to use the search bar but it yielded no results.
alright... now that i have that cleared up.
I am doing the swap from my stock 4.3L Vortec from the 1998 body to a 2001 5.3L.
I have:
The engine (5.3L)
The wiring harness from the engine.
All computers and control boxes attached to the new engine.
Fuse box from the truck it came out of.
I also have all the stock equipment as well that ive kept.
The 5.3 engine is mounted in the truck now ( had to buy the hooker header engine mounts that move the engine forward and up by a couple inches then had to cut the mounts off the truck frame and modify them so i could weld them to the frame as using the stock position wasn't fitting properly...
The setup was too "narrow" for the engine mounts from the new engine... HUGE PAIN.
My question is the wiring....
My idea is to let the new computers handle the new engine and all that and ALSO use the old fuse box and stuff to handle the ABS and gauges. I will have to splice in some wires like the speed sensor and temp gauges ect. but is that all? Am i missing something critical?
Thank you for your response! I know this is a long shot post.
If you have any specific questions i will give specific answers. I am not unfamiliar to mechanical stuff. This is just my first engine swap and i get a little overwhelmed at it all sometimes.
Justin
