S-10 & Blazer 1982-2005
FAN CLUTCH for SURE????
Old Apr 23, 2009 | 8:35 AM
dmhoo29's Avatar
Default FAN CLUTCH for SURE????
Okay, How can I be 100% sure my fan clutch is good or bad?
When I cold start it the fan starts out already making noise as if I had driven it on a hot day. After driving it 1/2 to 3/4 miles it returns to normal.
Should this be the norm? Should it be just opposite due to the cold start?
Thanks in advance.
Old Apr 23, 2009 | 10:47 AM
EvansBlue's Avatar
Most of the time the fan will engage for a little while on start, but usually by the time you get on the road, it clutches out.
Old Apr 23, 2009 | 10:57 AM
Mike Sigmond's Avatar
ROTM Coordinator
My truck does the same sometimes, Isnt there a temp sensor that controls it?
Old Apr 24, 2009 | 2:33 AM
dmhoo29's Avatar
Not sure. Let me know if you find out.
Old Apr 24, 2009 | 7:25 AM
MDTAHOE's Avatar
Professional Mechanic
It is normal. The viscus fluid in the clutch settles at the bottom of the clutch when it sits. As long it goes away it is normal
Old Apr 24, 2009 | 7:38 AM
There shouldn't be any leakage from the clutch,
don't confuse it with a water pump leak, as both fluids can be slippery to the touch.
There should be very little to no lateral movement at the bearing
There should be no roughness when you rotate the fan manually (with engine off of course)
pdrayton
10
May 5, 2024 2:27 PM
pdrayton
May 29, 2013 7:55 PM
SweetEmotion
Apr 27, 2012 8:35 PM
robertmalibu
Feb 27, 2008 8:41 PM
jimbo
Apr 23, 2006 7:27 PM
