S-10 & Blazer 1982-2005
Fresh Air Hose - P0304
Old Apr 2, 2019 | 12:11 PM
ten10ace's Avatar
Default Fresh Air Hose - P0304
Hi I have a 96 Chevy S10 4.3 that has been throwing the code P0304. I have changed all plugs, wires, new distributor cap and rotor and a new coil. Unfortunately I still have the code. Although, it doesn't sound like it is missing. This past weekend I was doing some brake work - changed the master cylinder and the abs sensor. When I got it all back together I wasn't showing the misfire code anymore and I didn't unhook the battery. I drove it for a couple days and still no code. I didn't understand but I thought great! Unfortunately, I was under the hood yesterday and I noticed that when I removed the intake hose to have better clearance to the master cylinder I forgot to attach the fresh air hose to the back of the intake. This is the hose that is connected on the back that runs into the manifold. When I hooked it back up the code returned. Any ideas or could you point me in the right direction?
Old Apr 4, 2019 | 7:03 AM
oilcanhenry's Avatar
Probably an air leak in the intake manifold, or in the EGR or PCV system.
