S-10 & Blazer 1982-2005
front rearend
Old May 28, 2008 | 3:31 PM
chevyman1978's Avatar
Default front rearend
was wondering ifi can weld my front rear end in a 95 chevy 4x4 truck and will it work normal when out of 4 wheel drive???????
Old May 29, 2008 | 7:59 AM
old dog's Avatar
Default RE: front rearend
uhm!!!!!!!!! please rephrase and explain just exactly you want to do .
Old May 29, 2008 | 8:22 PM
k whi wanna know is if i weld my front rearend up so when i put it ib 4x4 both tires will dig when i take it out of 4x4 will it be in 2 wheel drive or always locked up hope this explains it better and thank you for your answers
Old May 29, 2008 | 8:46 PM
old dog's Avatar
i dont know man but you lost me !!!!!!!!!!!!! dont weld anything !
Old May 29, 2008 | 8:48 PM
EvansBlue's Avatar
I'm assuming you are referring to the "Front Differential".[/align][/align]The differential is designed that way for a reason. If you lock the differential with a mini-spool or god forbid if you weld it, you can overheat the driveline and cause damage to the transfer case. [/align]
Old May 31, 2008 | 6:33 AM
yes i know it could damage something but i just want to know . when welded both tires will spin in 4x4 take it out of 4x4 will they not be locked up??????
freightshaker1
Mar 20, 2009 8:54 PM
JR Samples
Sep 15, 2008 8:25 PM
SimpleMan57
Mar 16, 2008 8:43 PM
joe200120012001
Aug 22, 2007 7:35 PM
BMDAKK
Mar 13, 2007 2:55 PM
