S-10 & Blazer 1982-2005
fuel pump
Old Aug 21, 2008 | 7:30 PM
cheapride's Avatar
Default fuel pump
1992 Chevy S10/T10 Blazer 4WD V6-262 4.3L VIN Z
I have a 92 Blazer that was running fine untilone week agowhen it cut off on me going down the road and would not start back.
I Had it towed homeI replaced the fuel pump,and fuel pump relay it still will not start .when I turn the key on I can't here the hum in the tank, I checked the old fuel pump by hooking it up to the battery direct and it works.
I used a test light to check the ECM B fuse (inside under dash ) for power it had power on both sides I also checked the fuel pump relay wires,the orange wire had constant power the other wires have power for 2 seconds when the swith is turned on,the black and white wire does not have any power either way
I went to the back where the fuel pumpwireshooks up and checked the plug( purple wire)that supply power to the fuel pump it had power but it was weak
Old Aug 21, 2008 | 8:47 PM
shawnvw's Avatar
Banned
Default RE: fuel pump
Replace the wire from the relay to the pump.
Sounds like there's some corrosion or somehting
mangomanj
Aug 17, 2014 9:51 PM
BRB
Dec 28, 2012 8:34 PM
hunter10220
May 18, 2011 8:37 PM
