S-10 & Blazer 1982-2005
Fuel pump issue
Old Jan 23, 2009 | 10:31 PM
  #11
nrgizrbny12's Avatar
The fuel pump for the model of my car only comes as a whole unit. You can't get separate parts anymore.
Old Jan 25, 2009 | 12:53 AM
  #12
Okay I got my fuel pump replaced and fixed and I did it myself. I have a 2001 Blazer 4.3 Vortec. I took off the cover for the gas tank, dropped the tank, took off the the 3 gas lines on the old fuel pump, took off the 2 hoses that you pour gas in to the tank, and unhooked the power and ground wires. *It's common for fuel pumps to go bad on GM and it's also common that the ground wire will short out so make sure you check that too.* I replaced the old fuel pump with the new on and put it all back together and I'm able to roll around again. Hope this helps someone.
Old Jan 2, 2011 | 10:20 AM
  #13
grez0214's Avatar
Having Similar issue, did you every figure out what it was?
mangomanj
Aug 17, 2014 9:51 PM
BRB
Dec 28, 2012 8:34 PM
hunter10220
May 18, 2011 8:37 PM
