S-10 & Blazer 1982-2005
Gas Gauge
Old May 7th, 2010 | 12:12 PM
darkside1971's Avatar
Exclamation Gas Gauge
Just got a 1997 Blazer. The old owner just recently installed new fuel pump & since then the gas gauge doesnt work. When the key is off the gauge reads 1/4 of a tank but when I turn the key on the gauge drops to empty. Any ideas on what to look for in the problem.
Old May 8th, 2010 | 9:00 AM
frickenbored's Avatar
since the fuel pump is new that means the sending unit is brand new also since they are built into the fuel pump. Assuming that the fuel pump was replaced was the original fuel pump when you install a new one the 4 pin connector at the pump has to be cut out and the newer style has to be spliced in, maybe the fuel gauge signal wire splice came apart.
ahearnm
March 19th, 2023 6:37 PM
73resto
April 25th, 2008 3:38 AM
wrxsubaruwrx
December 3rd, 2006 12:33 PM
pilot1996
Corvette
July 12th, 2006 10:01 PM
Quick Reply: Gas Gauge
