S-10 & Blazer 1982-2005
Having some problems with my 4wd...
Old Jan 21, 2010 | 7:39 PM
  #11
toad's Avatar
Well I guess that I spoke to soon. Although now the front pumpkin works fantastic the 4wd still does not work. Reffering to the diaphram under the battery tray I have no vacuum at that point. I tried to follow the lines back but im not sure I found the right spot. If I am correct it goes to a spot on the transfer case that 2 other hoses also meet and go down into the transfer case. Is that the vacuum hose I am looking for? What should I do to diagnos the problem?
Old Jan 22, 2010 | 3:26 AM
  #12
mudmaniac's Avatar
Ride of the Month
May 2009
I'm not sure how that part works but there is a vacum relay connected to the transfer case. I hope someone can help with that.
Old Jan 22, 2010 | 9:14 AM
  #13
toad's Avatar
Thats actually all the info I really need. I will find it and check it.
Old Apr 30, 2010 | 11:11 PM
  #14
Glenn Blaz's Avatar
I have a 2001 Blazer 2 door 4 wheel drive, When i start my car in (2 wheel drive) and sit there for about a min in park, My blazer automaticly shifts itself into 4wheel high then drops to low by itself. What could cause this? i have push buttons for the 4 wheel switch, I decided to take the fuse out in order to stop the truck from going into 4 wheel while driving.
Trouba
10
Aug 1, 2011 1:42 PM
WhiteZ28
Camaro
Mar 18, 2010 10:09 PM
Mike767
Jun 15, 2009 9:59 PM
cams 98 silverado
Sep 15, 2008 8:26 PM
lvegaskid1
Mar 5, 2007 4:19 AM
