Headlight Bulb Removal on 2001 S-10 P-Up
Alright, as easy of a task this should be, I can't seem to figure out how to pull the headlamp off to get the the bulb out and replaced. If anyone has ever done one of these before or has a tip or trick to help me in what should be a very easy job, please help me out.
Thanks
JK
Thanks
JK
There are two tabs holding in the headlight. They are on the inner side of core support. Pull them up and then push them back towards the rear of the vehicle. After those are removed, you can pull out the head light assembly.
