S-10 & Blazer 1982-2005
Help! Signal hyperflash
Old Aug 24, 2016 | 5:27 PM
JordanA's Avatar
Default Help! Signal hyperflash
Hi everyone,
This is my first post here after joining and first just want to say 'hi' to everyone.
I have this '99 S10 and the turn signals hyper flash in both directions (blink fast). In addition to hyper flashing, if you flip the switch for a right turn both arrows light up, but, the direction you chose will be dominant. In other words, no matter what direction you hit, it ''bleeds'' through to the other side. So looking at the front on a right turn, the right signal will be flashing (fast) but the left marker will also light up, but not as bright. Tail lights are fine. The hazards work just fine. I've changed all the bulbs and the flasher. It only has one flasher for both signals and hazards. Also, the front parking lights don't work at all(same bulbs as signals). Also, when I turn the parking/head lights on both turn signal arrows light up, even with the key off. And, the radio display(time/station) goes off when parking lights/headlights are switched on. I don't care much about the radio, I just want the signals to work properly, i.e only flash on the side it is supposed to. But I thought I'd mention it in case it's related.
Sorry my inaugural post was such a complicated problem. I hope I can be of some use to others in the future here, but this really has me stumped.
Does anyone have any ideas what this might be?
