S-10 & Blazer 1982-2005
how to pull codes
Old Apr 6, 2008 | 6:04 PM
my99s10's Avatar
Default how to pull codes
My service engine soon light, on my 1999 s-10, came on today and I was wondering if there is a way to pull the codes without using the OBD reader. I have a 2002 dodge stratus and if I cycle the key through the off and on postition 5 times on the odometer the codes will show. That is why I am wondering if I will need a OBD reader.
Thanks.
Old Apr 6, 2008 | 6:44 PM
EvansBlue's Avatar
Default RE: how to pull codes
No there is no way to pull the codes without a code reader. You can go to autozone and get the codes pulled for free I think...
Old Apr 8, 2008 | 10:42 AM
my99s10's Avatar
Thanks for the reply. I will head to the auto store to see what codes they pull. Is there a place on here were I could look up the codes to see what they mean?
Old Apr 9, 2008 | 6:50 PM
74chevy4life's Avatar
here this site might help they have most the codes
http://www.obd-codes.com/trouble_codes/
Old Apr 11, 2008 | 4:08 PM
rabbit0102030's Avatar
Former Moderator
Honorably Retired Member of Staff
Auto Zone pulls the codes for free, and they will tell you what it means.
Old Apr 13, 2008 | 3:02 PM
ORIGINAL: rabbit0102030
They will atempt to tell you what it mean...most the time they are just guessing what it could be or they are just reading off of the scanner which is just a general reference
Old Apr 13, 2008 | 10:10 PM
my99s10's Avatar
So I had the codes pulled today and it came out P0452evapcntrlsystem pressuresensor low. Any ideas were I should start at trying to resolve this issue.
Thanks!
Old Apr 14, 2008 | 8:28 AM
EvansBlue's Avatar
Common one.... thats good.
P0452
SCHEMATIC:
CIRCUIT DESCRIPTION
The fuel tank pressure sensor responds to changes in the fuel tank pressure or vacuum. This information is used in order to detect vacuum decay or an excessive vacuum during the EVAP diagnostic routing. The fuel tank pressure sensor signal voltage to the VCM varies from a minimum OF about 0.1 volts with pressure in the fuel tank to above 4.0 volts with a high vacuum in the fuel tank.
The fuel tank pressure sensor display on the scan tool has an auto zero feature which occurs at each ignition cycle and is corrected according to the barometric pressure. Because of this, the fuel tank pressure sensor display may not accurately reflect the actual output of the sensor or the conditions within the fuel tank.
The fuel tank pressure sensor diagnosis table is intended to isolate and diagnose the electrical problems with the sensor wiring or the sensor.
CONDITIONS FOR RUNNING THE DTC
The ignition switch is in the RUN position.
CONDITIONS FOR SETTING THE DTC
The fuel tank pressure sensor voltage is less than 0.1 volt for more than 5 seconds .
ACTION TAKEN WHEN THE DTC SETS
The VCM turns ON the MIL after 2 consecutive driving cycles with the fault active.
CONDITIONS FOR CLEARING THE MIL OR DTC
* The control module turns OFF the MIL after 3 consecutive drive trips when the test has run and passed.
* A history DTC will clear if no fault conditions have been detected for 40 warm-up cycles. A warm-up cycle occurs when the coolant temperature has risen 22°C (40°F) from the startup coolant temperature and the engine coolant reaches a temperature that is more than 70°C (158°F) during the same ignition cycle.
* Use a scan tool in order to clear the DTCs.
DIAGNOSTIC AIDS
1. Inspect the control module harness connectors for the following conditions:
o Improper mating
o Broken locks
o Improperly formed
o Damaged terminals
2. Inspect the wiring harness for damage. If the harness appears to be OK, observe the fuel tank pressure sensor display on the scan tool while moving the connectors and the wiring harnesses related to the sensor. A change in the display will indicate the location of the fault. Refer to Wiring Repairs in Diagrams.
TEST DESCRIPTION
The numbers below refer to the step numbers on the diagnostic table.
5. If the VCM recognizes the high signal voltage, the VCM and the wiring are okay.
rabbit0102030
S10 & Blazer DIY and Useful Threads
Mar 5, 2014 7:36 PM
littlemack
Sep 12, 2012 8:28 PM
hfl67
Oct 19, 2010 9:05 AM
mopar43
Apr 20, 2008 10:47 PM
Mechanic_Not
Nov 20, 2006 11:24 PM
