S-10 & Blazer 1982-2005
I need help!
Old Oct 5, 2015 | 8:27 PM
Bryan34's Avatar
Default I need help!
I replaced the distributor cap on my brothers '93 s10 earlier and when I did I pinched the pink wire between the cap and distributor. Now I have no spark or fuel pulse. I spliced the crimped wire, checked the fuses and replaced the ignition control mod. Still nothing. Any help would be great, thanks.
Old Oct 6, 2015 | 11:34 AM
Did you try and start it before you repaired the wire? If you did then you probably shorted the module.
Old Oct 6, 2015 | 11:43 AM
Bryan34's Avatar
I replaced the module, it will run when I jump the pink wire to 12v. I don't know if that helps
