Injector issues?
OK Guys, hopefully you can help me out here.
I have a 02 S10 4.3 crew cab. It keeps jerking when I go down the road, real quick, like its not getting fuel. It absolutely will not start until the third try. It has a less than one year old fuel pump, sparks plugs, and wires. this all happened before, and I was told to replace the spider injectors. I did it, and its worked fine for over a year until last week. the warranty on the injector was only a year. I don't know if I have bad luck or if these injectors just go bad. The VIN is a "W" Vin, and the truck also throws a code that amounts to my gas cap not being on tight, which it is always on tight. The code comes and goes depending on what day it is. Any ideas?
Thanks,
Joshua
Thanks,
Joshua
breeze.12
Apr 1, 2007 8:32 PM
