S-10 & Blazer 1982-2005
keep blowing ignition fuse
Old Apr 12, 2008 | 12:29 PM
raydar's Avatar
Default keep blowing ignition fuse
I just bought a 98 s10 from a friend. The truck broke down on her I pulled it here. After looking at it for a little while i found that the ignition fuse(under the hood) was blowen. I put a new fuse in started right up drove it around a little and parked it. The other day i drove it over to my dads when a went to start it and the fuse blew again. I had some extra fuse with so i put one in, the sec i turned the key to the start postion it would blow the fuse. Its a five speed so I put a new fuse in and we pulled it to start it. when i got it home and shut it off it started right up. I have no idea what is going on or where to start.
Old Apr 12, 2008 | 9:26 PM
shawnvw's Avatar
Banned
Default RE: keep blowing ignition fuse
what fuse are you replacing?...is it labelledin the fuse box?
Old Apr 12, 2008 | 11:12 PM
raydar's Avatar
The fuse is under the hood. Its one of the big fuses not like the little ones u find inside. IGN is the fuse that keep blowing. I hope this helps you, help me.
Old Apr 13, 2008 | 2:57 PM
74chevy4life's Avatar
are you putting in the right amp fuse?
Old Apr 14, 2008 | 4:45 PM
shawnvw's Avatar
Banned
Is the fuse for Ign A, IGN B or IGN C?
These fuses all power the ign switch directly, and your ign switch powers everything in the car. By letting us know which of the 3 fuses it is, we can norrow it down pretty good
Old Aug 2, 2014 | 9:17 AM
Trevor.car's Avatar
Default S10
I have the same issue it's the ign A 40 amp fuse please help
Old Jan 20, 2023 | 10:46 PM
Jake_'s Avatar
Default Please help
I have the same problem. Yes I know it's an 8-year-old thread. But surly by now someone has to know what it is.
Tracker Trailblazer
Jun 26, 2015 6:03 AM
brokeexpress
Jun 20, 2014 12:28 PM
heartless2
Mar 22, 2011 6:49 PM
txmusic
Apr 26, 2010 11:47 AM
My_Hoe
Oct 18, 2008 2:44 PM
