Liftgate glass alignment 96 Blazer 2DR
Hi Everyone,
Hoping can get some help in aligning my liftgate glass. Had to put a used one on from the same year, make, part number, etc. as my last one exploded. The glass fits ok but needs to go left just a 1/4 inch. Is there an adjustment for these things?? Where the hinge meets the body is a direct fit. There is a guide pin to line the hinge up with the screw hole. No room there for an adjustment. However, where the hinge meets the glass there is a 10mm bolt on the underside of the glass where I thought I might be able to adjust the glass. There has to be a way. I find it hard to believe GM made this a direct fit, take what you get kinda install. Do I need to use the old hinges?? I'll be digging them out of the trash just in case. Any help would be appreciated.
Thanks, Rob
Thanks, Rob
Texas07Sub
December 16th, 2014 11:39 AM
The_Stees
March 5th, 2013 9:20 AM
