lowering s-10 blazer
RE: lowering s-10 blazer
This is a really old thread but incase anyone wanted to know or if you still wanted to know then here you go.
I beleive on the 4wd that beltech makes drop keys. I don't know if thier any good or not but I think you can get 2 or 3 inches from that. That last inch or two is going to have to come from cranking the torsion bars.
For the rear you get a 4' block or you can combine a 1' block with a 3' lowering leaf springs.
You're going to have to notch out your frame if you want to go that low. you're also going to have to adjust your drive shaft pinion angles.
mattintc
August 14th, 2012 11:36 AM
