S-10 & Blazer 1982-2005
need help
Old February 18th, 2011, 4:27 PM
chevyman1981's Avatar
Question need help
i have a 95 blazer 4.3 vortect with gas coming out of the tail pipe what would cause this any help would be grate thx bobby
Old February 18th, 2011, 7:43 PM
come on some one must know what will cause this plz help me
Old February 19th, 2011, 12:05 AM
lynnboy021's Avatar
do you have any codes? 1 your spark plug might not be working 2 the cyl maybe is getting to much gas 3 you might have a stickey valve
Old February 19th, 2011, 12:18 AM
ther is no cel and i was told this by a grage that i took it too to get it inspeted and ther is gas coming out the tailepipe it is also all black junk in the end im stumped i did plugs and wires and cap rotor all test out ok with spark plug tester
Old February 19th, 2011, 12:22 AM
lynnboy021's Avatar
how is your rpm your idel does your moter shake when u give gas does it bog down any loss in hp?
Old February 19th, 2011, 7:58 PM
all of that im at a loss could it be head gasket ? and ty 4 trying to help me out
Old February 19th, 2011, 8:17 PM
lynnboy021's Avatar
no its not ur head gasket are u really sure its gas and not water that smells like gas?
Old February 19th, 2011, 8:33 PM
robbymorton's Avatar
I would wonder the same as above? You would think water would smell like gas coming out of the exhaust. Or maybe you have a cylinder not firing.
Old February 20th, 2011, 8:28 PM
it is gas 4 sure u can catch it in a cup and burn it i did plugs wires cap rotor and no change yet
Old February 20th, 2011, 10:36 PM
lynnboy021's Avatar
well you can remove your both valve covers and start up your truck and let it idle then go see if all your valves are moving if it is then i really dont know what it can be. if you still having gas come out then just google your problem....
Quick Reply: need help
