need help
ther is no cel and i was told this by a grage that i took it too to get it inspeted and ther is gas coming out the tailepipe it is also all black junk in the end im stumped i did plugs and wires and cap rotor all test out ok with spark plug tester
well you can remove your both valve covers and start up your truck and let it idle then go see if all your valves are moving if it is then i really dont know what it can be. if you still having gas come out then just google your problem....
