S-10 & Blazer 1982-2005
Needing help with 2000 s10 4l60e
Old May 5, 2017 | 6:13 PM
Glockguy706@gmail.com's Avatar
Default Needing help with 2000 s10 4l60e
Ok so here goes. I have a 2000 s10 2.2 flex fuel and I have error code for shift solenoid b stuck off or proformance. I replaced both shift solenoids and still have the code . I also have o2 sensor bank 1 sensor 1 and no back up lights. I replaced o2 sensor fuse. I think my security system was by passed but I don't get the electric code for shift solenoids. Like I did when the main round harness was umplugged . Could it be neutral safety switch? A bad ground ? Voltage to trans something stuck in valve body ? Anyone seem this combo of problems or are they unrelated . It seems to shift ok. Any help would be great and pics of the ground location for trans on mpls side and pcm side would be amazing . And anyway I could jump power to the o2 fuse that controls trans to see if it is working or sense it starts is it getting power atleast on sensor 1 bank 1 side with the mpls.
