S-10 & Blazer 1982-2005
NO fuel? No spark?
Old Mar 18, 2008 | 9:08 PM
XOKELIS's Avatar
Default NO fuel? No spark?
I have a 94 chevy s-10 balzer with the 4.3L, it dies one time andit sounded like it was not getting any fire so I replaced the ign. coil and the pick up coil. we got near the right timing and it started to run but then about two miles later it just died. so me and a friend of mine put in top dead center so if it was the timing it would have been fixed, but the problem still persists. Is it just because im not getting enough fuel of what?
Old Mar 18, 2008 | 10:18 PM
TransAm Man's Avatar
Default RE: NO fuel? No spark?
Welcome, it sounds like you have a few problems going on but I'm not quite sure. Have you had a shop look at it?
Old Mar 20, 2008 | 3:07 PM
shawnvw's Avatar
Banned
Have you physically checked for spark? might be a fuel related issue as well. check to see if it is indeed spark that is not working And also check your fuel pressure.
Old Mar 26, 2008 | 12:07 AM
XOKELIS's Avatar
Well I know there is no spark because I put carb. spray in the air intake and it never started up. But it starts up when the engine is cold but stalls when heated up. I talked to a mechanic and they told me the control module but I got it tested and passed.
Old Mar 26, 2008 | 3:14 PM
shawnvw's Avatar
Banned
Did you have it tested when it was hot or cold?....A lot of time they fail only when warm
mamulan
Aug 20, 2014 8:39 AM
stdhawaii60
Dec 24, 2010 11:14 AM
catill
Aug 30, 2010 11:07 AM
