Noise under hood
Noise under hood
1997 S 10 P/U manual trans.
I have this noise when the engine gets to operating temp. When it is cold, no noise at all. No noise before replacing the trans, but start to happening when I replaced the clutch. The clutch hasn't bled at all. I lift the crank pulley a bit to slid the trans into the engine. I put a new belt tension assembly. Any idea what this could be?
Here is a short vid:
try a mechanics stethoscope
