S-10 & Blazer 1982-2005
not your normal starting problem???
Old Sep 11, 2008 | 9:32 PM
taymax14's Avatar
Default not your normal starting problem???
I have a 2000 Chevy S10 with the zr2 package it has 127k miles and I've had it for about 6 months. I just use it for my lawn mowing business so I don't put many miles on it. every 3 weeks or so when I go to start it after finishing a lawn it sounds like it starts fine (fires over and then dies right away) so I turn the key and it goes up to 1000 rpms then dies within a half second. and I keep trying to start every 30 sec or so and it does the same thing for about 15 min then it will always just start normal. I have never had it not start agianI just have to keep try for awhile and it will finaly stay running. And when it happens sometimes it will happen 2 or 3 times in the same day and then I wont have any problem for the next 3 week. any ideas at all on what could cause this??? please help with any ideas or if you have had the same problem.
thanks
Old Sep 12, 2008 | 1:22 PM
shawnvw's Avatar
Banned
Default RE: not your normal starting problem???
Sounds like a problem in the passlock system.
When it doesn't start, turn the key on, and watch the security light....does it flash? if so, leave the key on for an aditional 10 mins(or untill light stops flashing), turn key off, then start the vehicle.
Old Sep 12, 2008 | 2:40 PM
taymax14's Avatar
sounds like it could be that. I think I do remember the security light flashing. what would cause this? or the problem in the passlock system? what does it mean when the security light flashes?
Old Sep 14, 2008 | 9:35 PM
shawnvw's Avatar
Banned
when the light flashes there is a problem in the system. Could be a wiring problem, module, but most likely the passlock sensor in the ign barrell
Old Sep 14, 2008 | 10:38 PM
taymax14's Avatar
ok ill have to watch and see next time it happens. also yesterday when I was driving I notice that the security light was on while I was driving, it wasn't flashing just on. what does that mean?
thanks for your help!
Old Sep 15, 2008 | 3:36 PM
shawnvw's Avatar
Banned
The security indicator is a LED display that is located in the instrument cluster. The BCM sends a class2 serial data message to the instrument cluster in order to inform the instrument cluster when to turn ON or FLASH the security indicator. If the security indicator is ON a DTC will be stored related to the system malfunction
So basically, is the light is flashing, it is in tamper mode and will not start. If it is on solid, there is a problem with the passlock system, a code has been set, and the system in in LEARN mode...trying to re-learn the resistances. But is there is a problem with the wiring or passlock sensor, is won't be able to re-learn it.
RazzMaTazz
Mar 18, 2015 7:09 PM
Mike Sigmond
May 31, 2009 10:35 PM
2LowK5
K5 Blazer
May 30, 2008 11:55 AM
BigHog
Cobalt
Jan 19, 2008 7:36 AM
CC037D
Corvette
Jun 4, 2007 8:43 AM
