S-10 & Blazer 1982-2005
OBD connection issue
Old Dec 12, 2008 | 6:26 PM
99Blazerman's Avatar
Default OBD connection issue
Recently purchased a 99 Blazer and went to take it to inspection and was told by inspector that vehicle failed because it was not driven enough. Has 200000 miles plus but runs great. He advised to run it for 100- 500 miles before bring it back.
I placed OBD scanner on it to check myself but scanner does not read.Screen is blank so I checked scanner with another Chevy and it works fine ,I then had it checked by Autozone who checked with Scan Pro and when it was turned on scannnerread there is no connectionbetween scanner and OBD connection.
Not sure what can be wrong as it starts and runs fine. Any help is greatly appreciated as I cannot get inspected until OBD reads correctly.
Old Dec 16, 2008 | 11:13 AM
johndb's Avatar
Default RE: OBD connection issue
You should first check your fuses as the scanner is powered buy the truck,most are the same fuse as the lighter.You may have to check every fuse as the owners manual does not tell you what fuse is for the OBD connector.Hope this helps.
Old Dec 16, 2008 | 8:03 PM
EvansBlue's Avatar
The fuse will be labeled CIGARLTR and will be in the dashside fusebox.[/align][/align]I don't understand how a vehicle could have failed inspection because it wasn't driven enough....[/align]
Old Dec 18, 2008 | 7:55 PM
Thanks changed fuse and works great now. will take back to inspection.
It failed becuase the machine could not pick up 4 of 7 systems .
I am gathering that because connection was not working there system was not reading codes off connection
Old Dec 21, 2008 | 6:03 PM
Dawn's Avatar
ORIGINAL: EvansBlue
It will fail because if at anytime the battery is unplugged, it resets your entire computer. So when the battery is hooked back up, the computer needs time to reset itself. And all the sensors have to re-heat themselves so that the computer can get a reading off of them.
kwdaye
Jan 12, 2011 8:18 PM
riffla
Mar 10, 2010 3:49 PM
wdidn
Jul 8, 2007 12:49 AM
ameisenman
Feb 20, 2007 7:24 PM
