odd problem
#11
in2pro i was thinking that was a possibility cause it was a low humming sound like it was pushing instead of sucking. so like i said i may move the two wires around and see what happens. but its been rainy and crap here so i dont feel like gettin sick just to try it lol.and thanks for the pin locations i will look into that as well
#12
Rather then swapping them, see if you can identify which one is the + positive with a meter, checking it to ground/frame... then use the wire diagram EinST provided to ensure its wired correctly...
when in doubt ohm it out... this can help prevent accidentally burning up the fuel pump motor...
#13
Professional Mechanic
What brand pump did you use? It should have come with directions and picture for correct connector installation. If the fuel gauge works correctly wiring is not your problem. Did you look to see if the fuel lines are pinched between the tank and body of truck. If you did not use a Delphi or Ac Delco pump you are sure to have a problem now or very soon
#14
well i had to go with an Airtex(pos) due to the fact that i needed the part last week and not today lol but now that i got to reading a few more posts and noticed some simiar problems but yet no final fix's i took my battery to autozone to get it tested and had a whopping 3v :/ so new battery is coming today and we will see what happens from here. i appreciate everyones feedback and advice. im not completely mechanically illiterate but sometimes it doesnt hurt to get a second opinion.
#15
ok so airtex is a POS and was returned because i jump tested it and it pushed nothing through. i jump tested the old pump and it poured through so i got my money back and got my truck to crank but now it idles funny and when i go to shift into gear it wants to choke out and die. any suggestions?
#16
You put the old fuel pump in with a new battery? You still need to check the fuel pressure, don't you? It should be 58-64 psi for VIN W (8th of VIN) and 41-47 psi for VIN X with key on, engine off.
#18
well i got her running today and starting on her own accord. it turned out to be the intake plenum gasket and a PCV valve went ahead and changed all three plenum gaskets (i.e. plenum, TB, and injector) bolted her back together and shot a squirt of ether in just in case. she fired right up and drove wonderful. still a little weak but also i do have 31's on it. well i appreciate everyones help and support.
davidsharp75
July 31st, 2006 10:04 PM
