S-10 & Blazer 1982-2005
oil leak problem
Old Aug 31, 2008 | 9:47 PM
BadBowTie82's Avatar
Default oil leak problem
my rear main seal is leaking oil in my 82 s-10... it don't leak that bad but when it does it drips on to my manifold and starts to smoke. Is there something i can do to stop it from leaking for a little bit until i have time to replace it?
Old Sep 1, 2008 | 10:21 AM
shawnvw's Avatar
Banned
Default RE: oil leak problem
oil stop leak usually works pretty good provided the seal isn't too bad. It usually takes about 500km to start working though
Old Sep 1, 2008 | 11:20 AM
old dog's Avatar
is it the main seal or the pan gasket ? might just have to snug up the pan bolts !
Old Sep 2, 2008 | 9:17 PM
the man who looked at it said it was the main seal....but it sat for year before ever being moved...but my oil pan does have oil dripping of the bottom
Old Sep 2, 2008 | 9:34 PM
if it was my pan gasket would it even drip on to my manifold to cause smoke?
Old Sep 3, 2008 | 10:11 AM
old dog's Avatar
yes the rear oil pan seal is in the same place as the rear main ,you need to identify which it is take the dust cover off the transmission and look to see if there is fresh sign's at the rear main running down ! you have to know were the leak is before you can make a plan of attack .
Eric Sherden
Sep 24, 2013 1:21 PM
deziking
Dec 28, 2012 10:06 AM
BobY
Aug 3, 2011 10:20 PM
95wt
May 30, 2008 3:07 PM
trush
Jan 1, 2008 9:27 PM
